Caporegime
- 28 Jun 2007
- Tamworth, UK
Very nice ![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
I tested my tap water to see what the levels are (I left the water for 48 hrs in a glass first).
Nitrates and nitrites were both zero, but ammonia was 0.5 ppm, I didn't think tap water would have ammonia?
PH is 8.2, is that normal for a hard water area?
How are you testing the water, test strips or liquid test kits?
Nitrate liquid test kits are notorius for reagents coming out of solution, you need to band and shake the bottles for a good minute or two to have a hope of a vaguely accurate result.
Sometime water companies use chloramine, so when your dechlorinator mixes with it, ammonia will be produced as the chloramine is broken down.
pH 8.2 is pretty normal along the Uk south coast, our water source is quite hard.
