Your thoughts please... 680 SLI and Surround or wait for GK110
Same problems here. The annoying this is you can't set a profile to switch so if you go back to separate resolutions on each and run extended desktop, you have to re-do the Bezel correction.
Which reminds me - I need to get Cleeecooo's attention. Rumour has it, he's a master on this subject!
I'm afraid I couldn't find anything on this and I just had to keep manually switching. It was ****ing annoying. I'll have a play around when I do my next build wih 570 SLI and 3 monitors and let you know.
Try 'Start button' and 'P'
Works with AMD :p
Crappy nvidia drivers :p
(Joke)
It's true though. If AMD allow you to do it properly then nVidia should implement something similar. There's 3 users on this forum alone in this thread who want it... scale it up across all Surround users? Probably a lot of them are similar.
Edit: Now 4 users! :)
(below)
This is one reson I hated 3 screens and I couldnt use them for games either so they had to go.
But ultramon was the closest I got to making desktop mode useable :o
At least with pro ultramon you can set up maximisation regions on the screen... so that'll be something at least - i'll have a play with that later
Just noticed something else - the IR emitter connection to the screen for 3d vision... if I want 3d on all three screens - do I need 3x 3D vision kits!?!?!
I'm sure that's a no - but it looks like it :S
3d vision emitter plugs into the pc via usb. It's just to sync the glasses with the screens.
I'm 99% sure you don't. One kit should work for all the screens.
there's a ps/2 cable? 0_0?
I don't remember having one, lol
Do you have the 3dvision 2 kit?
edit: just found the ps/2 connection in the box. I can't remember what its for.
ah, nvidia site says:
VESA Stereo Cable Port For use with DLP HDTVs and Quadro GPUs only
Ahhhhh... thank you :)
No, you don't need 3 kits.
Plug emitter into PC not the screens
Setup surround as normal then activate 3D in control panel and follow instructions-
anything else i can help with :)
