- 28 Sep 2018
I'd love to compare my manually tuned timings vs a XMP 4000. If anyone manages to get it working, please run AID64 and Timespy.
If you are still on the original bios you should update anyway as there have been memory compatibility and stability updates since then. It's a painless process and only takes a minute or so.
This is my result with Timespy in XMP @ 4,000mhz on the master. I got the saved file as well but im not sure how to attach it and I dont own AID64 so I can't try that.
https://www.3dmark.com/3dm/32955141?
check the speed is it running them at 3600mhz??
It is possible that Enhanced stability runs some lower timings "looser" so as to achieve stability or compatibility!!! would be good to have benches to see what this is doing exactly.... I in the run upto computex and new 8Pack products don't have time to test this out now.
