Said while quoting an equally "biased" outlier benchmark. I dunno what this guy's methodology is but other IPC tests do not have the same conclusions. Maybe he's using slow RAM, I dunno.its pretty much true. many know this in games except for people like humbug who uses same biased benchmark showing ryzen better lol.
Something wrong with that...
As i wrote on Reddit.
I was surprised to see TheGoodOldGamer latests IPC video in which his results show Zen+ IPC level some 15% lower than Haswell, he thinks its even lower for Coffeelake.
I cannot get my head around how he got these results given that everyone else who i have seen do the same thing with the same applications result close to Coffeelake, it just blows my mind how he can get results so wildly different to everyone else.
His Cinebench R15 scores are about 15% behind Haswell, his CPU-Z results about the same level of difference.
His Cinebench R15 results he claims with all CPU's at 3Ghz he thinks 122 for Haswell at 3Ghz and 112 for Zen+ https://i.imgur.com/ygezslY.png
Guru3d results:
4790K boosts to 4.2Ghz single core, they result 173 at that, 40% higher and that matches the clocks difference, 40% higher score vs 40% higher clocks.
But at 4.4Ghz the 2700X scores 183, 47% higher clocks vs 3Ghz but the 2700X is scoring 63% higher than his result with clocks normalised, so there is about 15% scores missing from his results on Zen+.
A far easier way is TechSpot, they did them all at 4Ghz.
See that ^^^ with everything at 4Ghz Zen+ is about 97% of Coffeelake, that compliments the Guru3D result....
I ran Cinebench R20 with a Coffeelake owner on another forum, and again his Coffeealke clock for clock was only about 3% faster.
https://forums.overclockers.co.uk/t...enchmark-thread.18849380/page-3#post-32566035
So how the hell is Chris getting these results on Zen+?, they are about 15 to 20% lower than reality.
CPU-Z exactly the same, his results are about 20% lower than they should be....
3 posts in a row........
Someone is defending hard![]()
But its so easy to debunk....
