***Official Ivybridge Overclock Thread***
16 Apr 2011
Southampton
Some people have bought the 3770k for the hyper-threading, not just to get to 5ghz. If your not interested in the hyper-threading then you might as well get the 3570k
8 Jan 2012
I bought the 3770k because I was like well it may come in handy one day. Doesn't bother me that it won't be used right this second and if I had to I could find several uses for it.
16 Apr 2011
Southampton
Same, at the present, I wont be using the Hyper-threading but I probably will do one day so I bought it.
I doesn't bother me that Iv'e payed 50% more than people with the 3570k, I have the added feature when I get round to utilizing it.
17 Dec 2010
Finally got round to putting my 3770k in.... Anyhow I discoverd that the cpu had marks on the IHS from what looks like a previous installation, the package itself though didnt look like it had been opened before.
I take it that this is from factory testing or something? Did anyone else see anything similar?
10 Nov 2006
Lincolnshire
O.k need a bit of advice....
Should be getting my Noctua tomorrow so want to get things straight, had a little play tonight with the stock cooler.
Firstly is it best to use Bios or Asus AI suite2?
Secondly is it best to overclock using BCLK or Multiplier or combination of both?
Thirdly I have 1600MHZ ram should I be aiming for an overclock which keeps the ram around these speeds?
Comming from an asus p6t and bio in the z77 are quite different.
Can anyone show there settings for reaching 4.5GHZ?
8 Jan 2012
You only have to tweak the multiplier and vcore and possibly llb for OC'ing now the BCLK doesn't get touched at all. You can make it so your RAM doesn't step up with the CPU increases in speed as well.
17 Dec 2010
Well, as long as it works I guess theres no problem for me really. Does worry me a bit though.
Will have to see how it overclocks.
OP
16 May 2011
Staffordshire
Assuming that Asus AI Suite is the windows based application similar to my MSI control center. I would use the BIOS, only because almost all changes you make in windows still require a reboot so BIOS is quicker.
Only clock using the multiplier. You will also need to change the voltage slightly.
The RAM frequency will only change if you change the BCLK. Best to leave this really, and you won't get very far with it.
22 Oct 2007
Ivy batch codes decoded (from another place):
"Just to clarify how to read batch code
For instance, L206B425
L - 1st letter or digit is a plant code (L = Malaysia)
2 - 2nd digit is a year of production (2012)
06 - 3rd and 4th digits is a week (6th week )
B425 - 5th till 8th digits is a lot number"
10 Nov 2006
Lincolnshire
So leave this alone set @ 100.00?
20 Aug 2006
OEM or Retail ?
