8 Pack looks at R290X
Man of Honour
21 May 2012
Dalek flagship
Looking good 8 Pack, But AMD do need to turn it up a couple of notches in Heaven Valley. currently the fastest Titan there scores 3800 @ 1380Mhz. thats more than 25% faster than Gibbo managed @ 1200Mhz.
Seems AMD is currently very bad indeed for Valley.
I don't like Valley as it bottlenecks the cards too easy unless you run it @1600p and then things can get a bit toasty.
6 Feb 2010
The thing is, for the Heaven and Valley bench, the superior memory bandwidth is probably not translating (much) into performance and score...or at least, that's what I think.
If we look at benchmark on Metro etc, it clearly show how scarily high memory bandwidth is able to impact on reducing frame rate loss:
http://www.techpowerup.com/reviews/AMD/R9_290X/18.html
Caporegime
17 Mar 2012
ARC-L1, Stanton System
The thing is, for the Heaven and Valley bench, the superior memory bandwidth is probably not translating into performance and score...or at least, that's what I think.
They are only for comparing Ball size anyway, in gaming overall it trades blows edges out the Titan, thats what really matters.
Caporegime
17 Mar 2012
Scaling is awful for multi GPUs @1080p
I can not beat 3 HD 7970s using 4 Titans @1080p :p
I score almost the same @1600p as I do @1080p with 4 cards.
Look at the Valley thread, those Titan's as the top are scaling ~100% core for core clock for clock against the 680's @ 1080P.
BTW, i have added 1440P to it, you want 1600P too?
Man of Honour
21 May 2012
Dalek flagship
What sort of a question is that!!
Now I have the mod the cards will get ragged!!!!
Here is some special overclocking wallpaper for you
Now give them cards some volts !!!
