- 28 Oct 2011
- Coil Whine Reduction Technology (Exclusive to Powercolor)
Is that glue?
Is that glue?
I'll send an email but I don't think it'll be good news.Have you tried contacting EK to ask if they may support any of the 8GB models? I thought they supported the 290X 8GB Vapor-X cards.
EK likely won't be making one, it's the same pcb as the 4gb 290x gaming and they have left that without a block since launch, can't see an 8gb variant adding any extra incentive.
Spend a bit more and get something like the pcs, which uses the reference 290x pcb.
Is that glue?
They do, those that use the reference pcb, msi do not on the gaming cards
Edit: refrence pcb or that tri slot sapphire monster have blocks available.
That's the problem, if I'm going to go through the expense (and effort) to buy new blocks, then I may as well wait till AMD release their new cards or Nvidia release the new Titan.
Got to be honest, I do like my 290X's, but selling my Titan was a stupid decision.
Is the MSI 290X 8GB quiet?....Also does it exhaust heat inside or outside the case?
What's the part number of the block you have, or full description at least. I'll get on my PC shortly and see if I can figure out your options.
Yes. (but hey it works )
To be honest I've had a ridiculous number of 290/X cards and not one of them has had even the slightest bit of coil whine. So whilst it's definitely still possible get a card with it, it is rare these days.
As a silence freak I rated the 290 gaming too loud. But some people say it is fine.
All the heat stays inside the case and is blown on the motherboard and case side panel (assuming a standard case layout)
EK Water Blocks EK-FC R9-290X is what is on the invoice from OcUK. I'll have a rummage around and see if I can find the original boxes and get you a part number.
It's ok that's enough to work with. It turns out ek released 'SE' blocks for TUL partner cards (powercolor).
From what I can decipher you have two options (need to hunt more for pcb pics) which are the reference blower 8gb and the recently announced sapphire tri-x.
I will dig a little more however as I can't be 100% by looking on my phone.
6 months away. And I'm not sure I'd be buying the VERY FIRST cards to come off the production line anyway. I'd want to see what was available and upcoming.
Right now I'd settle for just an announcement as to what we can expect!According to the AMD CEO we should have new cards in July at the latest.
Thanks, that certainly puts my mind at some ease then. So would I be OK with the 295 X2 also in that case? I see that comes with a 850W PSU minimum, and I've seen some people saying it's very power hungry, but more so than x2 290X in Crossfire?I think you'll be fine, just make the next upgrade a PSU if you want to start overclocking the graphics cards.
If the PSU does not like it, it will trip (switch off) to prevent damage and will shut down the computer.
Thanks, that certainly puts my mind at some ease then. So would I be OK with the 295X2 also in that case? I see that comes with a 850W PSU minimum, and I've seen some people saying it's very power hungry, but more so than x2 290X in Crossfire?
