HP Microserver+XPEnology
31 Jul 2003
Somewhere far.
Hi all,
This is going to be a silly question to some of you Xpenology veterans but I'm not sure which method to best proceed.
I've had my N54l running for a while with a 4TB and a 2TB drive. I've been gradually ripping my collection of DVD's and Blu-Ray's to it and I'm nearing the point where I'm going to need another drive as I'm about 80% full.
What I'd like to do is configure Xpenology in a way that I can add a second 4TB drive (for now) but in future can add bigger or smaller drives and have them act as one big 'pool' for my movies. I can see I can move the movies folder onto a different volume but once I've filled the 4TB drive, I'm not sure if I can span some films onto the second drive.
Would SHR be the best method for this? The drives will likely be of varying sizes as the years go by and the prices of storage drops. Can I keep them as single non SHR/non RAID volumes and make the folder with my films span across multiple drives?
Thanks.
Edit: I should add, the drives are currently in 'Basic' mode - not in SHR or a RAID array. Doing a bit of background reading, I should be putting them into an SHR or JBOD setup. Which would be preferred, and can I change from Basic to either option without wiping the drives?
29 Nov 2005
Just managed to create a 12 disk system using:-
3 x Microservers
1 x LSI MR SAS 9240-8i SAS/SATA 6g 8port RAID controller
1 x PSU extension/splitter cable
1 x molex power extension cable, plus 3 x 1-into-2 splitters
1 Microserver is used to host the XPEnology USB, 4 drives using the on-board SATA and the RAID card.
I've used two older Microservers (one with a faulty motherboard) effectively as drive enclosures, with the SAS cables running from from the Microservers into the RAID card. Bit fiddly to get the cables to run through
For power, I've used an in-line power splitter in the main Microserver to trigger the PSU into one of the "enclosure" cases and run a power extension from that case into the other enclosure case (don't fancy running all 12 drives off a single supply).
Had to disable the eSata and OD SATA ports to stop XPEnology picking those up first and ignoring 2 ports on the RAID card - otherwise no other tweaks were required.
Given the price of a 12 disk Synology system, I'm really pleased with this :)
The master server is located in the middle in the photo below
19 Oct 2002
Woolyback Country
Hiya what size drives do you have connected to that sas card,and what make please?
Also i have 1x6TB red in my Gen 8 as Basic
I am currently installing 2x6TB reds as SHR
After the SHR has finished setting up and i have copied over all my files,do i just choose`Remove` for the 1x6TB as basic and then add it as a SHR third disk?
If i do this all my data that is on the new SHR disks will be safe yes?
29 Nov 2005
I'm using Samsung Spinpoint F4 2TB (HD204UI) Internal Hard Drives
Correct :)
19 Oct 2002
Auckland, New Zealand
Just wasted the last 3 days scrubbing and trying to add another hdd :(
only to just find out that you can`t add a 4TB drive to 3X6TB shr array:o:p
Bugger:D
Yeah its a bugger, I've always kept a 73GB drive attached in the array so that any new drive only has to be bigger than that, although it doesn't help if you add a bigger drive as the next drive must then be equal to or bigger than the last drive added.
18 Oct 2002
UK
I setup Xpenology on a Microserver last night, works great, I went for a baremetal(?) X64 install, so no esxi, just straight usb install.
Now my query, apologies I am a frigging goof when it comes to networks. I want the NAS to be accessible from anywhere in the world, and users (who I give logins too) can write/erase files to their section of the NAS. I know nothing about this.
What do I need to run/do/open (ports etc) to achieve this?
I don't even know what synology call this feature?
I don't want them to login in and control the NAS, just a way they can transfer files?
stupidist post on the forum right?
Idiots guide anywhere?
3 Jun 2005
The South
Image the USB drive with .5592; follow the Web Wizard for a migrate and use the manual option to select the .5592 PAT file; update to 'update 2' via DSM when it reboots.
Took all of about 10 minutes.
3 Jun 2005
The South
Web Wizard being - http://find.synology.com (saves having to use the Synology Assistant software).
You could use a different USB flash drive or image it but you'd still need to reinstall the previous version of DSM (via the PAT file) as DSM lives on the hard drives and not the boot drive (USB flash drive).
10 Jan 2009
Thanks mate. If I'm feeling brave enough I might try it later :)
where is the best place to get the usb image and the .5592 pat file?
