***The Vapers Lounge*** 3.0
30 Jan 2009
Aquilonem Londinensi
Anyone have suggestions for a small device that's easily pocketable? Currently have a Coolfire Mini with whatever tank it came with, but it's square shape is quite awkward for trouser pockets.
E: must be refillable and have easily available coils
18 May 2010
Innokin Apex, it's the latest in their tube mods, takes easy to get coils, usb-c and 1800mah battery.
Not tried it myself but will be ordering one soon.
I only use tube shaped devices for the shape, easily fit in the pocket
Man of Honour
20 Sep 2006
Can you use the juice they sell at Tesco in a normal sub ohm kit?
Due to RM and Amazon issues around here I've been unable to get any for a week and I'm almost empty.
18 May 2010
Ordered and returning, constant burnt hits off the pre installed coil, didn't bother trying the other coil as far as I'm concerned if a coil is duff it's going to be a constant issue when buying replacements.
Getting another voopoo v suite instead
Permabanned
7 Aug 2017
by the tower the one up north ..
only use coils in 1 mod the abyss .. VAPORESSO Ceramic EUC Coils last forever had 6 tanks thru this one .. :)
rest of my mods i build myself .. easier cheaper
23 Jul 2009
Bath
My old Geekvape Aegis is getting a bit worse for wear, and I fancy a change. What are people recommending these days for a robust box mod? I only really go up to 100w (typically 55w) so don't really need a crazy 200W mod, but a dual 18650 is a must
Things I like about the Aegis:
- built like a tank. Has been dropped many times
- simple
- nice snug battery fit, no rattling
- settings can be locked so it doesn't change in your pocket (without having to lock the fire button)
- comfy to hold
Things I dislike:
- micro usb charging (not that I use it, but in a pinch)
- battery door latch prone to bending after serious drops and needs bending back or batteries can lose connection and disconnect mod
- menu navigation is a bit fiddly
10 Nov 2006
After 35 years of smoking, As of today, I am 2 weeks cig free.
I was filling up with fuel, and suddenly without knowing what I was buying, I bought a BLU bar disposable Vape.
Was something I had been thinking about for a while, and with the Wife and Daughter away for a few days, I thought it was as good a time as any to try.
Have not lit up a cig since. I have really surprised myself.
So far so good.
8 Jun 2007
So far so good.
Well done mate keep it going.I was the same 8 years ago still vaping.Get the Smoke Free app on your phone and put your details in.
I'm currently at a saving of £40,000 since i stopped :eek: less the cost of vapes and juice of course.
