- 14 Jan 2014
Looks excellent, I have a Sliger S620 which I absolutely love and have no thoughts of selling, but I'd love to try this case out also...argh!
I’m the same. I’m currently back in the NR200 and while it’s slightly larger than the C4-SFX, it’s a great case for the money. Not sure I can justify the £200 price tag at this point.Looks like the product pages have been pulled - guessing they reached pre-order capacity. Edit - Back up again
Have followed this case for a while now and it looks amazing but at the price point, I'm not sure it's worth 4 times as much as an NR200.
Might, 15L is massive though.
Think Dan was saying to put fans first to solve that problem.Got mine yesterday, built my 7800x3d in with a gigabyte aero 4070
Having an issue where the ekwb nucleus 240mm aio won't line up with the AIO mount on the case. I've had to bodge it in with a few motherboard screws so it's not secure, but can't see any other way of fitting it. The radiator seems too wide for the mount
Might add some double sided tape to keep it more secure
Otherwise from limited testing on it, so far so good
Yeh I spoke to him on discord, unfortunately the nucleus has another part sticking out of the rad body to stop the tubes from bending too much, so not sure if there's enough room to mount it that way. He suggested some radiator gaskets to clear the flared part of the mount which stops the holes lining up, so I've ordered some to try outThink Dan was saying to put fans first to solve that problem.
I would personally just buy another one and sell the EK.Yeh I spoke to him on discord, unfortunately the nucleus has another part sticking out of the rad body to stop the tubes from bending too much, so not sure if there's enough room to mount it that way. He suggested some radiator gaskets to clear the flared part of the mount which stops the holes lining up, so I've ordered some to try out
Yeh forgot my wifes PC has an EKWB 280mm AIO so I'll swap them overI would personally just buy another one and sell the EK.
Any more updates on your system and how your getting on with it?Got mine yesterday, built my 7800x3d in with a gigabyte aero 4070
In the end, I swapped out the 280mm AIO from my wife's build and put it in mine, and my Nucleus went into the Meshlicious she has without any issueAny more updates on your system and how your getting on with it?
Just ordered this case. I believe ocuk are supplying North American customers too along with orbit, hope the backlog isn't too big
Ordered one to the US on June 2nd, also hoping the backlog isn't too big.
Tried reaching out to support but they don't have any estimates.
Read somewhere online that OCUK gets their stock from CaseKing and the C4 seems to be in stock there, so hopefully they'll get some stock from them at some point this month.
