So much better than I was getting, still priming just passed 1024k on all 4 cores.
HEADRAT
1024K, that not small ffts is it?
Wazzatjust took Prime 95 (25.4) and started it up
Help!!!
I'm at 3800, 1.47 real for 30 mins prime
core temps 66 66 62 63
CPU Temp 70-74
So I stopped it.
Whats causing my high temps?
D-tek fuzion water block, single rad, swiftech mini res, and the pump I don't know the make of, 400 l-ph
If I changed the pump to a swiftech 1200 l-ph, would this help a lot bringing the cpu temps down.
I tried a big house fan pointing into the case, and it made no difference.
So what is it?
Pump?
Rad?
So far I've only touched cpu vcore, the more 'xtreme' your overclock the more use they are to you.
For anything to around 3.8-4ghz on a g0 quad with a good board i would say only cpu vcore would need to be changed.
My P5K Deluxe isn't the same however, needs a small FSB Termination voltage bump to get my x3210 stable.
Pump and rad by the sounds of things, you might want to pick up a DDC 18w or DDC ultra and a dual or tri fan radiator.
Swiffy's MCR and Thermochill's PA range are the top two.![]()
Help!!!
CPU Temp 70-74
So I stopped it.
So what is it?
Pump?
Rad?
Nice. What are your other settings that you're using for you mobo if you don't mind me asking. I'm completely new to this Intel overclocking malarky after years with AMD so would apprecicate some pointers or at least a starting point. Cheers![]()
Your Conservatory![]()
easyrider said:OK stop there.
You are talking out of your depth.
easyrider said:Temps are not his issue
Servo said:So I stopped it.
How many posts in a row?
Give me a break. You're out of your depth.
Core 2 failed for me at 4hrs 3.8ghz 1.55v needs more ...(testing)
How so?This is BS
Sorry mate
How so?
That is exactly what I have gone through so how the **** can it be BS?
I have boosted both NB and SB vcore for low temps at 3.6ghz
