Hornchurch
Sounds like you need to read an overclocking guide ,but basically what you want to do to find the best speed is to increase the FSB in small steps,do a quick 5mins Orthos test & increase FSB again until it crashes in a quick 5min test of Orthos ,at that point you can either increase a voltage (just cpu or just mbrd) or lower the FSB & retest.Keep doing that until your rig can pass Orthos for 24hrs.
Btw if increasing a voltage makes no difference drop it to default & try a different voltage (say switching from vcore increases to northbridge increases)
Don't increase voltages too much & watch temps during testing.
Personally I wouldn't increase CPU vcore over 1.45v ,& preferably not over 1.4v ,depending upon your cooling.
An 8hr Orthos test is nowhere near enough nlel1975
[edit]Looks like I never reported what speed I got out of my E6420.
Whilst I managed to get my C2D rig upto 3.35GHz (at less than 1.35v vcore
) in windows it wasn't stable ,turns out my MSI 650 mbrd isn't stable over 400MHz FSB.
So I've finally settled for 3.2GHz @1.3125v vcore & NBv @1.4v ,passed a 24hr Orthos test
,I haven't bothered with screenshots as I'm nowhere near the top end overclocks.But if people want s/shots then LMK.
Its a pitty my CPU is being held back by my mbrd but its still pretty quick & runs quite cool.
