- 26 Feb 2007
- Blackpool
okie kokey!
Ill try 0401
Ill try 0401
so stick on Bios Revision 0401, Change the LDT multiplyer to 2x, and slowly keep upping the FSB?
Put NB Voltage to 1.5v, memory 1.92v & Vcore to 1.47v's?
That sound good guys? & if it locks what do i up?
Thanks Will.
So, I get a pencil? As in those you write on paper with? Then just draw a line on it once or twice? just applying a small amount of pressure?
And I do the second image right?
Are you sure this will be fine? I mean, pencil and a PC component, sounds like a disaster lol.
I used 2B pencil which was more than enough for the task. I applied 3 strokes and had to use rubber to wipe some off as it was overvolting my chip.
Apply some pressure with the strokes and just make sure the 2 ends of the transistor are connected.
Just done 2 hours - priority 10 Orthos CPU test. LDT Frequency is x2 aswell with 1334FSB and Memory linked 889mhz - 3:2 ratio.
All fine![]()
What is LDT frequency and what does it do?
Excellent. Well im happy with 3.0Ghz... But what should i get GTX or Ultra and how much will i get for my GTS on the Bay of love?
oooooo.... just opened CS Source and Windows Live messenger at the same time and my PC just rest and came back straight on.... no error messages or anything. Temps are fine. Any ideas?
Just HDD throwing a wobbler?
