 - 18 Oct 2002
 - Manchester
You should be fine deadlifting but no one can tell you that but yourself.
Cissus only helps with tendons, not joints so you need to work out exactly what the problem is. I have a niggly knee injury and it turns out it's the patella tendon. Google that and loads of info will come up.
If it is the joints and the surrounding tissue then glucosamine/chondroitin/MSM can help, as can fish oils. These won't help with tendon injuries though.
