You cannot edit what programs are there, it will add them there by itself depending on the programs you run - the ones you use most often go there hence why it's called the recently used list
Yeah tried both those ideas, but if you look closly there is a bar below the top 3 apps. Every time you add a shortcut they appear above that bar! No idea why!
Doesnt really matter, would just prefer that look if poss
