Wallpaper please!![]()
mrk, how do you get your programs listed in the start bar like that?
If I try and drag a program into start it will only appear above that line, where you have your folders. http://robbiekhan.co.uk/root/mrk/desktop.jpg
Ive figured out how to make the icons small but, I like the way you have changed it.
I meant how do you get your programs listed here,
Still can't seem to edit what programs I want in there tho :S
right click any shortcut and select "pin to start menu".
or just drag any shortcut, hover over the start button for a second, wait for the menu to pop up and drop it in place.
You cannot edit what programs are there, it will add them there by itself depending on the programs you run - the ones you use most often go there hence why it's called the recently used list![]()
