- 2 Oct 2004
- PROPER Shields
Bigmouse how did you make those picture frames on that wallpaper on your desktop?
ta
Read below mate, if you want me to make them for you, just e-mail me the images (see trust) you want and sort it, only takes 5 minutes with a bit of care.
Fairly easy in any image app, just crop the pic you want, then add a white border to it, the rotate as you want, I think he just used layers of the same image, then add a bit of shadow effect, plonk it on the background.
Spot on.
Although you have to be a little careful when rotating the images, they tend to get jaggy edges, so it's worth rotating, then cutting the rough edges.
