Hi Conrad11
just testing your script, got error message
also can you explain bit more how to use it?
there are 2 folders, "albums" and "image" so i just create folder "Cars" in this albums folder and put all images in Cars folder?
where is "thumbs" folder, i cant find it anywhere lol
thanks
Apologies....just realised...that is a PHP5 function, if you have an earlier version of PHP on your server it won't work.
I shall fix that when i get back from the gym. I'll manually create the function.
EDIT:
To actually use it, when i post a working script up:
All you have to do is stick the folders/images in the "album" folder. The thumbnails are created by my script and the folder will be created when you first create a thumbnail
