- 15 Jan 2004
- Hall
yeah? DeFranco's programs are really good
I keep hearing about this whey protein powder, so I think I'll give some a try. The only thing is...I've only heard of the advantages, but what are the disadvantages?
Should whey only be used by the most serious of 'bodybuilders', or can it be used by individuals performing 'lighter' workouts? Can it also be used by non-gym goers?
One last thing, do you pronounce it WHEY(that rhymes with GAY)? Or, do you say the letters? Stupid question, I know.![]()
How much is the chicken there?
what's wrong with a nice loaf of chicken? beaks hovis by a mile
.Is it fine to make up shakes like the day before for the next day with say skimmed milk? is it fine to do that?
Front Squats,
Back Squats,
Stiff-Legged Deadlifts,
Calf Raises.
Think you need some more quad work do some lunges. Do not do leg extentions, they're knee wreckers!
Legs curls are for the hammys not the quads, SLDL's are much better and yes use a barbell.
Step-ups are very good yes, use them or lunges don't use both aswell as the front and back squats. I wouldn't anyway.
Yes I do mate. There's a block of wood about 2" thick that I put the balls of my feet on to elevate the toes, I find this is a great way of learning how to engage the hammy's properly. Any little trick helps with this very difficult exerciseFor SLDL's do you use a step at all? it was recommended to me.
