The ONE AND ONLY ***OFFICIAL*** Crysis thread - SPOILERS!
Ok, here's a pano comparison of modded cfg vs "high" (stock)
Modded CFG (DX9, HIGH)
No CFG mod (DX9 HIGH)
Notice the foliage has edge AA and a better look, water also has a more natural look to it, it also has CA. The background forest also has more hazy look, it looks more like DX10 on Veryhigh
And some other screens using custom cfg:
http://robbiekhan.co.uk/root/games/crysis/configmod/splode.jpg
http://robbiekhan.co.uk/root/games/crysis/configmod/jump.jpg
http://robbiekhan.co.uk/root/games/crysis/configmod/mavity.jpg
^ Here I threw a guy into the water and followed him in, I was surprised that Crytek had implemented real world underwater physics too! the guy floated for a bit then slowly started sinking (torso first) and his arms/legs remained higher than the rest of his body until he hit the floor, thumbs up!
The more I play this the more fun I have in SP mode, the beach is just excellent to mess around in and it's such a beautiful level.
How did you make the images like that? they massive.
Right...
On the mission where you get air lifted out - then back in to a war zone...you are tasked with destroying 2 AA guns. Where the **** are they? I've literally been stood on the green dots and I cannot see ANYTHING? It's the same when I'm asked to destroy two arti's....
Right...
Its not the actual guns you destroy but those mobile controller trucks.
hey, could you post your settings and which file did you edit ?
plus
your spec please ?
thanks in advance.
Anyone know anything about servers for multiplayer?, looking to get one but can't find a lot of information about anything, apart from server commands. Thanks.
Just completed crysis, overall thought it was a good game although a few bugs caused gameplay to lock up.
Half way though COD4 now, havent yet decided which i like the most so far.
Crysis was totally ruined for me, the part when you fly the aircraft through the valley i had to switch to low settings, and what the hell is up with those tornados?
In game I spawned the wide angle lens adapter for the nanosuit.
¬_¬
:p
plus
your spec please ?
thanks in advance.
I just created and added the autoexec.cfg lines (see a few pages back!) and went from there :p
All on "high" with q6600, 8800gt, 4gb 800mhz
I'm still stuck. I'm at the ship yard...what do I blow up? The only thing I've destroyed is the jammer controls on the ship :/
I'm stuck on the final boss :(
Started playing the game from the start again in the meantime until I find out how the last alien is meant to be killed. No matter what I do I get owned by the sheer amount of aliens flying at me, and I struggle with ammo.
Thats before I mention the act that on the aircraft carrier when the fights kick off my fps drops to around 1/4 of its normal pace, at around 10 fps. Got a low of 6fps yesterday :(
Well I didn't get a reply so I'll ask again. What happened to cooperation with the koreans?
Quite clearly twelve years from now they still can't get Koreans to cooperate. Although, it has to be said, they are clearly using English to alarm each other, so in 2020 the tide is definitely turning... ;)
After disabling the jammer, you blow the ship up.
Use your binos to target it for an airstrike.
To stand half a chance You gotta get those FPS up a bit ;)
I'm stuck there too
whatever I do I cannot get a lock onto it and the game just sits there! Keep reloading previous saves but no luck, don't get shot at, don't do any damage.
Grr.
Hi all, I was in a similar position to you in regards to defeating the final boss but heres how you do it:
grab yourself lots of Guass ammo and a rocket launcher
when the boss comes out of the sea, shoot the four turrets on it,
then shoot the little alien things that attack you
then get some more guass ammo and a supply of rockets (lots of them dotted around on the flight deck) and just keep firing on the two arms, the outer shields should then disable and you can lockon to the ARM with the TAC gun.
do the same with the other arm
then it will get mad :P lol and do the same and concentrate fire on the stomach/centre torso where it fires the ice thing and then it gets mad and begins to rise onto the ship.
On its underneath it has a thing that opens and closes, shoot it with the rocket launcher to open it and get a quick TAC lockon and fire the NUKE..
then it begins to fall onto the ship and capsize the ship, run to the far end of the flight deck and pshyco picks you up in the VTOL...
then watch the big daddy alien explode :P
I can't. I can't find the AAA guns to destroy. I go to the green dots on the map and there's NOTHING there (no computers or anything). I get on to the ship...and Psycho says to turn it off (I press F and nothing happens - so I'll presume it's off). I then try and paint the target and nothing happens. The only red thing in my mission list is "meet with captain XXXXXXXXXXXXXX".
