see my comments a few pages ago (the long post), hopefully will help....
Thanks..most helpful!
Dear Señor Azza, Your Order has been packed and is in the process of being shipped.
drunkenmaster - What kind of stand can you get to replace the existing one? Is it easily done?
And is the "Wobbliness" that bad?
It has VESA (VESA MIS-D 100) mounting holes so you can buy any VESA compatible stand. I don't find the wobbliness any problem at all but I have a sturdy desk (which is on a laminate flooring with concerte underneath). I can imagine if you put it on a smaller desk it might wobble a bit more (especially if the desk was on carpet with floorboards underneath).
I did just find one that looked good after a quick search but was £75Can you not just get a stand that replaces the crappy stand even if its VESA (mean stands on desk and looks not bad). ?
Couple of pics of the monitor sandwiched between my 2007WFPs
Apologies for the quality, I'm not the best photographer
Having 3 screens is just fantastically awesome, I can have everything open at once, it really is a joy to use. Still need to buy some monitor (speaker) stands, then I'll be chuffed (they're on the floor at the moment).
any decent ideas on how to cover it up apart from tape?
Get a black marker on it to dull it? That's what I intend to do![]()
