250mm seems to be very wide?! Is that from the rear to the front off the oval stand?
105mm from the front off the monitor to the rear without the stand? Just trying to work out much room its going to take on my desk. Thanks
Stand pushed back against the wall the screen face is 17cm from the wall.
Seriously , if you want to fix £250 worth of kit to the wall using 4 self-tapping screws feel free (I'm not quite sure if I should put a rolleyes in here or not).
Wooo! Mines arrived!
Its quality!!!
Gaming = great as well.
Highly recommended!
Is there some special method to register for the warranty as the L-2442W is not on the model list on the warranty registration page ?
Other than that small problem I'm loving my new monitor![]()
David take a look at my post above, you experience any of those issues?
Yes. And it won't come out again unless you unclick it under the base.One niggle.
The base. Should the neck of the monitor click into the base?
Yes. Putting my thumb on the power button touches the surround and you need to push to get it to switch. I think it's good. The buttons and markings are certainly very discrete.Another question:
The buttons on my panel are pretty deep in the monitor. I mean I can press them but I really have to push the ball of my thumb against it. Especially the power on/off button.
Anyone else experience this?
Three lbt, WOW! How come you need three?
Also lbt, are you 100% sure that the mounts available fit those holes (in the monitor) perfectly?
Because he is hardcore.
I ordered one yesterday at 1430hrs, but it would appear that it was too late for next day delivery (and here I was thinking that orders received before 1600hrs were shipped same day, as per the website).
Anyway, I shall receive mine on Monday and will see what all the fuss is about. I shall be coming from a CRT background so will be able to give an insight into how this monitor compares to a good CRT.
The question you asked lbt, was it in reference to the holes on the base? Or the holes on the back of the panel?
