How do you get rid of acne?
22 Oct 2004
Im using teatril oil with cotton wool to wipe my face, then i wash it off with a warm flanel then wipe my face wit clearisil wipe. Been doing that for over a month still doesnt work, kinda annoying being 22 and still getting spots.
Any advice?
After you've had a normal wash in the evening, wash your face with savlon also.
I had really bad acne and this cleared it up for me, within a couple of months there was a huge difference.
Stop eatin and drinking crap, tends to cut most of it out, i only get the odd spot every so often, wash your face twice daily, take care of your body and skin.
My mate advised me of this one and it worked so... i now reccommend it.
James.
Own the major ones, wash your face on a regular?
Thats how i get very few spots :)
Go to the docs. Mention you heard something about a lotion called Zineryt.
Lots of people use it, and it's better than any pap you can buy off the shelf.
I have the same problem - I'm 23 and still get spots, despite using facial wash et al.
Clearasil ultra pads do quite a good job, but are somewhat harsh (if you don't wash your fingers after using them you'll soon see the top layers of skin removed) so not great if you have sensitive skin.
Apparantly a Sauna is meant to work wonder, ive been in one at the gym and they do make u sweat badly, must be doing some good, join a gym, get a fit, use the sauna and see if it works, give me a few weeks ill let you know my skin is looking.
I do get the odd spot every so often so, lets see how often they now come..
Patience, I've used about 4 different medicines, and about 5 different creams all to no avail, they were all prescribed.
All the clearasil/oxy/witch crap doesn't work. Just wait it out, I've had acne for 5 years now.
Any advice?
