Stock or clocked?
What programme are you using to monitor your temps! (try core temp),
Which thermal paste did you use.
Rob
I did put a very thin layer of thermal paste on, becasue everyone says you should not put to much on.
Could I try putting more paste on?
If you use to much it can make your temps worse, If you used Arctic Silver, you only need a small line accross the processor, which gets spread out by the Heatsink.
Ignore the above, down load core temp and see what that reads.
Rob
core temp wont install, says it has an error :S
Are you using Vista 64bit!
If yes you will need the new version which was posted on these forums, I will go and seek.
Rob![]()
http://forums.erodov.com/local_links.php?catid=18
I think this is it
Edit: After install, you need to click coretemp_startup file first then the application
http://forums.erodov.com/showthread.php?p=15559
This is where it came from and it worked for me. Did you un-install the first one?
Hi,
Found the links, I've included the original thread from here, make sure you read the post in the second link because every time you start core temp you will need to click on 2 other files which are zipped to the same directory, I didn't and wondered why it did not work.
http://forums.overclockers.co.uk/showthread.php?t=17801499&highlight=core+temp
Rob
