How would you expect it to run on:
x2 3800 @ 2.7
2GB RAM
x1950 Pro 512mb
Windows XP SP3 RC1
I'm not one for having all the visuals on. I can happily run without AA and AF (even though i know that would be totally unrealistic with my system) and with low settings as most of the time it still looks great.
Would the gameplay make up for this?
My friend stupidly bought this the other week for his 3 year old pre-built system. Only had a FX5700![]()
He's offered it me for a tenner so just wondering if its worth it.![]()
I played it on high everything with 16 x aa in xp 1650x1050 and it used 1.3 gb ram and between 30-50% cpu much less than I expected after all the moaning I've been hearing ! No stuttering at all ,unlike oblivion and stalker,so if you can play those games your be fine !
You cant of played with 16xAA, it wont be playable with anything over 4xAA, infact all high, 1680x1050, 2xAA it would be choppy in places.
what ever you say![]()
Whats with the rolleyes? Its a fact you were not running at 16xAA, its not possible on current hardware!!
he probably made a typo, 16x AF (anistropic filtering) is probably what he ment. i doubt anyone would be stupid enough to purposly say they ran it at 16x AA (anti-aliasing) at high settings at 1680 rez and got playable fps.
I cant even install the dam disk. Just ticks in my dvd drive. Its the special edition and the other disk reads fine.
yeah mine does that. you just have to be patient.
tell me where you got this fact from !
maybe not in vista but its a fact that is what I'm running it at on xp !
says whoThe fact is the game will tank and tank obscenely at 16xaa, 4xaa on most systems at high res is barely playable. If you are somehow magically running at 16xaa you must also be running at 800x600 with everything set to low, 16xaa on high settings at a hi res is NOT playable yet (not even on sli systems) and thats all there is to it.
says who![]()
even at 800x600 it wont be much good with 16xaa too.The fact is the game will tank and tank obscenely at 16xaa, 4xaa on most systems at high res is barely playable. If you are somehow magically running at 16xaa you must also be running at 800x600 with everything set to low, 16xaa on high settings at a hi res is NOT playable yet (not even on sli systems) and thats all there is to it.
