- 26 Apr 2004
- Milton Keynes
Yes that would affect the temps, as its breaking the air flow.
Anyone have any experience of clocking these chips in an Abit AW9-MAX? I've offered to help a friend out but I've no experience of this board, so any help appreciated![]()
3.4ghz stable for 8ish hours linkage not bad for second stab at this board abd cpu
Are you using a cooler on that CPU?
Think 82C is a little too toasty![]()
dam central heating would a air con in winter be over the top lolMight be worth trying it if he already has the CPU in the board, it could be worth a shot, I just wouldn't expect much![]()
Finally found a spare few hours to play around with my chip![]()
3.150ghz on stock 1.23V so far
Hey guys, does anyone OC their Q6600 on the asus ai gear?
If so, any tips?
tatts, you have taken longer than me to start overclocking your rig!! your temps are great! with that vid you should be good for 4ghz with as little as 1.5-1.55v.
If so, any tips?
