Awww
I know I thought he liked me...lol
He pretended to to get me to sign up.
I feel used
Awww
Not sure what your beef is?
You invited me into Benchtec the other day on MSN and now I'm your enemy.![]()
I have done nothing but ask why you (if testing cpu stabilty) was using blend instead of small FFT.
Posting a 4.8ghz 8500 gaming overclock without a prime stabilty test is meaningless imo.
Would you agree that finding the stabilty is initially done with small FFT?
No,.
3. small fft's for 8hrs min (cpu stability)
I need better cooling as Orthos fails as soon as it hit 70C (after 5mins)
I want to know why and how 8 hours became the magic number ? what if it fails after 9 hours ? does that make it an unstable clock ?
Exactly in your opinoin.
If some one posts a screen shot of their CPU at a speed they are happy with and works fine for them, then there is absolutely no need for you to go asking people where is this stability screen shot, where is that 12 hour prime screen shot, blah, blah, blah.
Just keep your opinoin to yourself for once god damn it. No one wants to see you in every ******* thread saying, that overclock doesnt do it for me, its not stable enough blah, blah, blah, no one gives a damn its just getting old now.
Nice vent Azza, you'd of thought the guy would have found something else to do by now![]()
But you just said:
Jeez...are you simply on a wind-up again or simply confused with technicalities? I'll try and make it simple for you.
If a cpu is no where near stable...it wont even post, if it posts it has a minute amount of stability. Minor stability gets you into windows. From there I go superPI, then occt....gradually increasing the workload on the cpu to get an idea of max benchable clocks and max 24/7 stability.
I posted my batch number somewhere on here, Too many E8*00 threads
It had a A6 in it.
Currently @ 4.05Ghz with 1.38v
Idles @ 40C using a TR SI 128 and an Amber fan.
40c seems rather warm idle when you compare it to mine, mine idles at 34c at the same clock speed and volts as you, this is with a Tuniq Tower 120.
Why the attitude?
I was just asking the question.![]()
