Damn, can only get my e8400 up to 3177mhz, was expecting a bit better.
Had the following settings, tell me if anything looks dodgey:
CPU: 353fsb @ Auto voltage (also tried 1.225v, also failed)
Mem: Set to 1:1 so RAM is only 706mhz (so below the normal 800mhz, can this still cause problems?) @ 2v
Running it on an Asus P5K and OCZ 2gb Platinum. Using stock HSF, intend to replace it but I was still expecting a little more from stock with this chip.
It will most likely be your RAM timings that are causing the problems here. Also I wouldn't trust the auto voltage. Yes it has got a lot better over time but still can't be trusted in my opinion.
Try 400x9 - You'll have to work out the voltage yourself though but just use other people's finding to work out what should be acceptable and then work up from there. If it boots and runs at the first voltage you try then just make sure it's stable and knock it down one increment in CPU voltage until it's not stable any more so you are using the least amount of voltage possible. Run the RAM at 1:1 as that will give you the DDR800 that you require and a 3.6Ghz overclock. Set your timings at what the RAM suggests and give it the correct voltage for stock use. If this all works then you are going to have to play around with the RAM timings to get a higher CPU speed maybe or you might be lucky and the RAM will run at the timings specified but at higher than 400FSB.
Hopefully this will get you past the low clock you are getting now and you can continue further. It's a task but you'll manage it
. Please post back with your results or problems and we can try to get your speed up.
) booted it back up, everything back to stock.... and now if fails the small FFT test
Im currently using 4x 1 gig of corsair xms2 c4 mainly to see how 4 sticks run in this board ! (coretemp is odd still ...as reports say, one temp a lot higher than another)
, up a whole 15fsb so far compared to before
(3311mhz).
