Well from your previous posts im reckoning you can only pull 40kg or something? lulz.
A lot of people here would be able to do it.
That's a good point actually, though some of the machines in my gym go up in 7.5kg steps, annoying tbh!! Even so they still go up in tidy uniform numbers and not all over the place as pointed out above.SK07, The weight steps you quote seem rather strange for something marked in kg (142, 156 and 178) as every machine I have seen progresses in 5kg steps.
Those values if taken as lb convert rather nicely to 65,70 and 80kg....
No personal attacks in here!! Big Kev
It would have to be a serious piece of kit to have so much weight too! Most I've seen are stacked at 100kg or 120kg.
I'm LOL'in at that one...hehe
Im pretty good at the old lats myself....and probably max I'd be happy with over 100K's. He's nearly twice that heavy!
Agreed...Ive never even seen a pull down machine with that weight...and ive used a good few gyms.
You'd recommend this without a squat rack? surely he wouldn't be able to use any kind of high weight.
This is a pathetic post.
I didn't think this forum was about slagging people for their lifts?
Tonight I trained biceps and quads. Managed to curl 50kg on the straight bar for 6 reps then on the seated dumbbell curl I got 8 reps out at 26kg.
They are very difficult and the wrist thing gets most people. I have to use a crossed arm style and it's a pain in the ass.The danger is having to clean the bar then lift it over my head with a normal squat. This is eliminated by a front squat as, as Chong says, the bar can be dumped if it can't be cleaned.
Anyway I tried it at the gym and couldn't get my elbows high enough, so I just lifted the bar over my head and did some light squats. In the meantime I will work on my wrist flexibility and hope they get a squat rack! If I can't get the front squat sorted I'll have to look at hacks or the smith machine, only I can't imagine hacks provide the same core workout that high bar squats do.
I'd do hack squats if I were you, I wouldn't use the Smith Machine. Maybe give it a try, some people seem to get on with it, I just can't.
To be totally honest though I'm no expert on leg press, I think I've done 20 sets total in my whole life. Don't like them and the only thing they seem to make you stronger at is... leg press? haha
Well saidCertain people need to calm down, no personal insults will be tolerated.
