11 Feb 2008 at 23:03 #141 iSam iSam Soldato Joined 12 Aug 2004 Posts 6,105 Just updated. Seems ok to me.
11 Feb 2008 at 23:04 #142 MagicBoy MagicBoy Soldato Joined 18 Oct 2002 Posts 19,375 Location South Manchester Took me about 3 minutes to download!
11 Feb 2008 at 23:09 #143 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire cymatty said: My downlaod was only 181mb Click to expand... PowerPC baby it's where the loves at
11 Feb 2008 at 23:19 #144 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent I want the cool transparency back! Can barely see anything through the drop downs now. :/
11 Feb 2008 at 23:20 #145 MagicBoy MagicBoy Soldato Joined 18 Oct 2002 Posts 19,375 Location South Manchester Me too. At least give us the option...
11 Feb 2008 at 23:27 #146 Logsi Logsi Soldato Joined 19 Oct 2005 Posts 10,508 Location Kernow WotDa said: There's two different ones. Click to expand... How come? Some guy on macrumors (RUMOURS DAMMIT!!!) had two identical iMacs, one took the 180 the other took the 341... My PowerMac Dual G5 and MacBook Pro both took the 180mb one. Josh
11 Feb 2008 at 23:29 #147 markyb markyb Soldato Joined 28 Oct 2002 Posts 3,214 Location Essex Got the 341mb here :s MacBook 2.0Ghz C2D.
11 Feb 2008 at 23:30 #148 Fillado Fillado Associate Joined 19 Jul 2004 Posts 2,039 Location West Yorkshire MagicBoy said: Also got a Sync warning just after boot regarding a conflict between iCal and my phone. Not seen that before. Click to expand... I got that as well, but I have seen it before (using an N95 8GB)... The problem for me is that iSync won't even open, if I drag it to the dock it gives me one bounce and that's it
11 Feb 2008 at 23:33 #149 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent 5bjoshua said: How come? Click to expand... http://docs.info.apple.com/article.html?artnum=25799
11 Feb 2008 at 23:35 #150 Logsi Logsi Soldato Joined 19 Oct 2005 Posts 10,508 Location Kernow WotDa said: http://docs.info.apple.com/article.html?artnum=25799 Click to expand... Argh, i want the big one! Josh
11 Feb 2008 at 23:38 #151 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent 5bjoshua said: Argh, i want the big one! Josh Click to expand... That's what she said.
11 Feb 2008 at 23:38 #152 barnettgs barnettgs Soldato Joined 22 Jan 2005 Posts 2,831 Location N Ireland Ok, a few little changes for the better: Documents stack folder icons when clicked, are bigger so they're much easier to see. When ejecting external HDDs, you don't get any pop-ups anymore. Is it my eyes or the Dock icons and tool menus somehow look clearer to me? Internet browsing on Firefox feels snappier? Time-machine - useful 'running' icon which shows it is running the back-up. I've disabled the transparency menu option under Desktop/Screensaver in System Preferences - transparency gives no benefit whatsoever.
11 Feb 2008 at 23:45 #153 Logsi Logsi Soldato Joined 19 Oct 2005 Posts 10,508 Location Kernow WotDa said: That's what she said. Click to expand... Ho ho hooo! Josh
11 Feb 2008 at 23:47 #154 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent 5bjoshua said: Ho ho hooo! Josh Click to expand... Needed to be said to make my mind off of the lack of transparency in drop down menus... I might go for a little dig and see if I can find the setting actually... Edit: Cool new effect on the login box for incorrect passwords, which probably isn't so helpful as it doesn't tell you your password is wrong. Last edited: 12 Feb 2008
12 Feb 2008 at 00:01 #155 MrMoonX MrMoonX Permabanned Joined 31 Dec 2007 Posts 10,034 hating the lack of transparency in my drop downs, but my airport on my macbook seems to be flying now
12 Feb 2008 at 00:02 #156 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire Finally updated, downloading the graphics update at the moment. Feeling a bit sluggish at the mo another restart should do the trick though.
12 Feb 2008 at 00:04 #157 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent On my 3rd restart now, 2 of which were for the updates. Sorted the disk permissions and roasted my lap at the same time too.
12 Feb 2008 at 00:30 #158 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire Looks like there is a 2008-001 Security Update out too
12 Feb 2008 at 01:19 #159 OllyM OllyM Soldato Joined 16 Aug 2004 Posts 6,331 Location New Jersey, USA All installed, seems snappier to me but I can't believe they've got rid of the translucent menus!
12 Feb 2008 at 01:52 #160 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Has the default menu bar transparency changed too? Sure, mine has a grey sky behind it but I'm sure it used to be more transparent.
