Once a VT30 (Fail cert) has been issued it voids any currect Pass cert mate regardless of it's expiry date.
Would the fuel leak as vapour?
I mean, if you spill some fuel majority of it dries away relatively quickly.
Also, isn't that quite dangerous and could result in Hollywood special effects endings?
) which thankfully, was cool.[TW]Fox;11138006 said:Are you absolutely sure about that? I was under the impression that was only for faults considered 'unsafe', otherwise it totally defeats the point of getting the MOT done early and getting the '13 month' MOT.
(Not that anyone does that
) , Once a fail is issued the only LEGAL journey you can make is to or from a test centre OR to or from a place of repair but you are NOT exempt from prosicution & you insurance may be void.Wonder how many people know about that law.
)pfft my mondeo only failed on ball joints that i knew were going (in fact i took it in to have them done and said throw it through the mot whilst you're at it)
It even passed it's emissions and it's decatted!![]()
As said it's all in the waffle on the back (but nobody ever reads it)
What it actually says is:
"This document tells you that your vehicle has not been shown to meet the minimum legal requirements for the reason(s) detailed in section A. If you intend to use your vehicle on the road you should have it repaired and retested before the existing test validity expires"
Which would seem to indicate that you can still use it up to the point that the existing test becomes invalid, it doesn't say anywhere that a refusal of a certificate voids the existing one.
Edit: I only have a VT30 because I forgot to clip some PAS pipes to the bottom of the engine after changing it.
Edit 2: Also covered on this page Link
Yep I'm sure mate i've got 30 years in the trade & 27 of them an MOT tester, Read the back of the fail cert(Not that anyone does that
VOSA said:An MOT certificate is valid until its expiry date. However if your vehicle fails a test before this date and you do not rectify the defects then you are driving an unroadworthy vehicle which is an offence.
VOSA said:So to put this into context if your car fails the MOT due to illegal tyres then you are driving an unroadworthy vehicle, you were driving unroadworthy vehicle before the MOT, and you will be driving an unroadworthy vehicle until you get a new tyre. Therefore at anytime if caught you would be subject to a £2500 fine and 3 points per illegal tyre.
However once you get a new tyre your car is roadworthy and the old MOT is still valid until its expiry date, thus you can then drive your car again and get it retested to your timescale, with out worrying about driving without an MOT.
I don't read that little VOSA paragraph as saying if your car fails, it's okay to continue using it up until the expiry date, at which point you should get it fixed.
Linky to source http://www.mottest.net/mot/mot-failure-question/
You are merely driving around in an un-raodworthy car
You've been talking about this leaking fuel tank for about a year now, surely it's no surprise. Infact it probably would have saved you money if you fixed it earlier
unlucky AGW, it's not nice when they start smacking the sill with a hammer and lots of bit comes off is it![]()
