Man of Honour
- 5 Jun 2003
- Falling...
Any advice on how to improve my routine would be great. Bearing in mind I'm up at 5am every day and don't get home till around 630-7pm during the week I have to do my best. (And who said senior managers didn't do any work?!
I vary exercises a lot between days so all the exercise listed for say chest I don't do at once, I'll pick 3 exercises, or maybe 3+1 superset. And I alternate weeks, i.e. 1 week I do heavy, 1 week I do light.
I do it on a rolling roster, in case I can't do that day (come home late or knackered) I just carry it on to the next days. On days where I don't do weights if I go to the gym I'll play basketball, or do some rowing or that sort of thing. Or play squash or go for a plod (I don't call it running
Also it's quite complicated I sometimes split Day 1, and day 2 with day 4 depending on time - just to get a mixture of exercises.
I've showed a range of weights they vary from light days and maximum on heavy days (and my current 1RM in brackets) - of course I don't do every exercises listed in one session as I said I've just showed every routine I do do.
Weights in KG.
Day 1:
Chest:
Incline Bench 60-95 (105)
Flat Bench 60-110 (125)
Decline Bench 60-100 (110)
Incline DB 22.5-35 (40 max DB weight )
Decline DB 22.5-37.5 (40 max DB weight )
Cable Flies 20-45 (55)
DB Flies 15-25 (30)
Narrow grip Dips 3x 12 reps + 1 rep till failure
Wide grip dips as above
Weighted Dips 5-15 (20)
Biceps:
Preacher curls on W bar 27.5-50 (60)
21s on olypmic bar 25-30 (32.5)
Hammer curls 15-22.5 (25)
Oylmpic bar standing curls 15-30 (35)
Day 2
Legs:
Olympic bar Squats 60-150 (170)
Front squats 60-80 (90)
Leg press 100-280 (300)
Calf raises 60-100 (125)
Lunges 60-80 (90)
Triceps:
Skull crushers 22.5-32.5 (40)
Cable pull down 20-60 (70)
Tricep extensions 12-20 (22.5)
Weighted tricep dips 20kg plate
Day 3
Deadlifts 100-170 (190)
Powercleans 60-100 (105)
Bent over rows 60-100 (115)
Lat pull downs narrow grip 60-100 (100 is max weight)
Lat pull downs wide grip 60-100 (100 is max weight)
Cable row 60-100 (100 is max weight)
DB pull overs 35-40 (40 is max db)
DB one handed rows 35-40 (40 is max db)
Cable cross over back extension 20-45 (55)
Day 4
Shoulders:
Shrugs 100-130 (150)
Lateral raises 12-17.5 (20)
Side lateral raises 12-17.5 (20)
Military press 50-80 (90)
Arnies 20-25 (27.5)
DB press 17.5-25 (30)
cable raises 15-30 (35)
It's relatively accurate. Certainly on the middle range weights my 1RM vary a lot though on average all the weights are going up. I'm hitting the limit of my gym equipment in some areas which sucks.
Weights in KG.
Day 1:
Chest:
DB Flies 15-25 (30)
Biceps:
Day 2
Legs:
Lunges 60-80 (90)
Triceps:
Day 3
Day 4
Shoulders:
Arnies 20-25 (27.5)
