200w will be way over kill for 5 gallons, not that it matters since it'll have a thermostat, but I would just buy a new 25w/50w heater.
Hey, thanks for taking the time to post, but could you go over these points?
when you say hot water, Is this boiled in a kettle? how much hot water? etc
also point 3:
do you make up the mixture with hot water or cold?
You can get the proper wrapa rround heaters for about £9.99!
what the hell is thatif I used reverse osmosis water instead of tap water?
Would it make any difference if I used reverse osmosis water instead of tap water?
Also there's a lot of kits to chose from, got any recommendations?
The total mixture needs to be around 20-21 degrees. If you put yeast into cold water you can kill it. Same if you put it in to hot.
I would have thought it might detriment the taste since you're removing everything from the water.
Is tapwater best for these kits? or is it just a case of it being pretty much free
It all depends what you like, but I would recommended getting a more expensive kit, you can certainly tell the difference.
The MUNTONS PREMIUM GOLD range is very good.
http://www.art-of-brewing.co.uk/acatalog/AoB_OnLine_Catalogue_Beer_kits___Premium____________9.html
two thirds down the page
The wife and I brew mead and various fruit wines. We're due to brew up LOTS of mead very soon (now that we're seasonally correct), so I'll post a guide if anyone wants![]()
 Ive ordered some Muntons gold India pale ale as it sounds very interesting -#Also whats the best way to accurately make the % of the beer, im thinking 8% or 10% per pint.
How much does it smell if you do it in your house?
