- 16 Jun 2007
- London
im sure his do. esp with that ICE Q one
500 sheets just for the motherboard and 4gb ram? **** that.![]()
if one wants to spend 2k, one should get the best![]()
not sure m8, but i would advise the Q6600 over the Q9450 ( £100 difference is not worth it)
i'd get a q6600, decent p35/x38 motherboard and 8gb of decent ddr2 ram and still have loads of change from the 500 you had budgeted for the motherboard and 4gb of ddr 3 alone.
One should get a 28" monitor and save money on other components. The premium you pay for the best isn't worth the extra 2 or 3 fps you get.
Is what I'd get, but one can only dream![]()
Isn't that always the case?Also why no 9800 series card? Answer: there's no point spending more than £200 for a car ad this point. Nvidias new gen is out in a few months and if you spend wads on a GPU now you'll feel very silly in a short amount of time.
Good spec but I would get a 9800GX2 and Noctua fans all round for silent running and 8GB ram, as the ram price is so cheap at the moment.
You'd get the most expensive and most pointless GPU upgrade before the GT200 arrives a couple/few months away? And 8GB of RAM even though its completely unecessary and he won't need that until DDR3 is well into its maturity? Interesting choices.
New gpus come out every month. Systems like this buy the best gpu you can.
Of course you have to upgrade at a later point lol... when the new CPU platform comes out, which will be Nehalem in early 2009. 8GB isn't anywhere needed, it's a waste of cash. As I said, by the time 8GB is utilised in any real sense over 4GB, we will be well into mainstream DDR3... and very likely the next version of Windows.Ram is so cheap get 8GB now and then you don't have to upgrade at a latter point.
No we're talking about new architecture, something which hasn't happened for about 2 years.. That's completely different.
