I have an odd Crysis problem and wondered if anyone had heard anything similar - searching various forums hasn't told me anything interesting.
Anyway, at the end of Exodus when you get into the VTOL there is the cut scene where Strickland does his stuff. At the end of the cut scene the VTOL door goes up and I assume that the next level should load.
When I play the door goes up and it is dark, however the sound effects, engines, aliens, gunfire continue. The first time I played I sat and waited and waited and then it started to reload my last save (as if I had died). I have now figured that even though the screen is essentially blank I am still in the game world and can run about, pressing esc brings the menu screen with a screenshot of my game (like normal) pressing escape again everything goes blank. Move around a bit and hit esc again the screen shot has moved on again.
Now I know that my specs are not ideal, 4800X2 with a 1900XT and 2GB ram but up until now the game has run fine. I am on 1.1 patch and the only advice I can find online is to reinstall and run unpatched to see what happens.
Anyone got any other suggestions?
Every other game forces you to use their 'Features' usually with contrived level design.
