Why does that matter?
Its no different than having a mobile phone clipped on your dash
If looks prevail over functionality then good luck to you.
I would rather have fingertip access to my entertainment when doing a 5hr
drive than what it looked like.![]()
One wire over the dash is "in the way" to me.
Secondly, you can't see your vents, so a function is not only with something "in the way" but, in reality, is completely obstructed.
It matters for the reasons I have given you numerous times already. Try reading.
It looks turd IMO (in MY opinion, MINE, not yours).
Explain to me how he WOULDN'T have fingertip access to the same media if he had spent the time actually recessing the screen into the dash?
Can't see the vents does not mean they cannot be used.
The plastic plug in ones.Well, we can just agree to disagree![]()
If you are both talking about using the centre blowers with the screen in place, you couldn't. Does get hot. I certainly wouldn't anyway, I'd block them off and use the door vents if I had a screen installed like that.
Yes,
And this being my first car PC install I'm happy.
*******$ 250 on a double din bezel does not offer enough titillation right now.![]()
Obviously not bothered about the whole vent thing. Right.
It will die 100 times quicker that way, trust me. Heat kills everything electronics wise.
Wait for a cold day, whack on full cabin heat, watch your screen die.yeah
No issue,
As there wasn't one.
My vents are fully functional
And do not hinder my usage of my air con before the screen was in place.
Wait for a cold day, whack on full cabin heat, watch your screen die.![]()
Explain?
And be cold, aceI just turn the vents off?
Keeping the ambient in car temps as what i want.
With respect...Do you think I'm stupid?
