Mmmm just slipstreamed a cd with the exe you guys kindly put up now none of our VL Keys work. All Five of them say invalid key...
Anyone have any idea whats happening?![]()
My VL Key works just fine. I only have 1 so cant try any others.
just slipped into my XPSP0 disc
Code:D:\sp3\i386\update\update.exe /s:D:\XPCD
Erm, how you do that?
Anyone know if it's possible to patch the SP3 UXTheme.dll? Will nLite do it?
http://www.ubern00b.net/WindowsXP-KB936929-SP3-x86-ENU.exe
Itll be up for a few hours so grab it now. Please dont plaster it all over other forums or Digg it or something silly
edit: use a download manager, multithreaded downloads will work far better for full speed.
Damn. They didn't include IE7, WMP11, WGA.
wish they'd make a second pack, like a 100mb all-in-one update pack that's slipstreamable too
Just for a heads up, in SP3 MS have removed the option to have the address bar in the taskbar!
bit early for that
check msfn / neowin, it'll emerge soon, then nlite will have it implemented
Okay, think I've found the solution to the install problems that Dougsnake and I encountered. When I ran the install last night, I had my removable hard drive still attached to the laptop I was installing on, as I had taken a Ghost image just pryor to the install. The SP3 installer proceeded to extract itself to the USB drive, and promptly failed.
I've just tried the install again tonight, with no external drives attached, and it's completed successfully.
and has no where near as much programs on it.
everything ive tried resulted in exactly the same access denied bull just have to live with the fact it makes me look like ive got pirate windows
I had a problem with it wanting to extract to an external HDD rather than my XP install. All i did was open the .exe in WinRAR and manually extract and run it from C:
it'd install faster from another drive (unless it's usb2, which would probably hamper the install time)
It was definitely faster installing from the laptop's local drive than letting it extract and install from the USB2 drive.
I would be interested to see if someone could do a test install and make sure there was an external drive attached, just to see if it fails in the same way as I got.
