A bit more substance here:
http://www.mikepettigrew.com/afterlife/html/u_k__study.html
I can't help but feel your out of body state may have been triggered by something other than a spiritual experience....like lots of drugs.....
My dads friend was wasted and chased a snail called sammy around the floor, doesn't mean it actually happened.
Lysander - Video of you moving stuff with your mind or spinning pendulums around!
Heres a question: regardless of any supernatural or spiritual hocus pocus
Why in hell would your consciousness seem to leave your body???? i mean wtf?? just why? Why would certain chemical reactions in the brain do this? Why is this induced at all?? Utterly BIZARRE imo...
nevermind arguing whether its a spiritual experience or whether its drugs doing it... Its just CRAZY weird that it happens at all!
Figure that one out for me k thanks
Surfer said:nevermind arguing whether its a spiritual experience or whether its drugs doing it... Its just CRAZY weird that it happens at all!
well certain kind of pain killers stop all sorts of signals going to your brain so it can feel like you no longer have a body as the nerves which tell your bain where your limbs are are no longer saying your arm is here etc so your mind then tries to figure out whats happening.
Your consciousness is not part of your physcial body. It's the other way round, your physical body is part of your consciousness and possibly a very small part at that. We've generaly forgotten this because from an extremely early age we're told that the world only exists through our 5 physical senses.
It's not weired or crazy it's just that western science and the rational midest is a lot more limited in it's view than people realise.
.... each are still mindsets/paradigm from within which phenomena is given meaning.Whether its called Western Science or some Hokey Religion.... each are still mindsets/paradigm from within which phenomena is given meaning.
I'd like an explanation that doesnt rely on such dogma. Basically free-thought not tied to either mast.
Tefal just so you know...i have experienced whats known as "Out Of Body Experience". Also get what you describe all the time when im falling asleep....
What you're proposing here is that people "think" they are outside of it but really they arent. So basically they are mistaken or deluding themselves in some way?
One of the main factors that debunks that idea is the Massive change of perspective you get
Yes i know some drugs will alter your perception totally but why would they make it seem that your body was over in one corner while you were floating around somewhere else? (with the same distinct clarity and perception i might add) Why would it do that? I'd like to see the scientific reasoning behind it..
I don't think it's any coincidence that we only use 10% of brains (at best)
thats a myth.
I found the most basic site to explain it for you
http://faculty.washington.edu/chudler/tenper.html
Ok maybe I should have said our conscious mind only access's 10% of our brain.
He's not pulling it from anywhere, there's no proof whatsoever of it.
Unfortunately I don't have the Necessary degrees PHD's etc in neurochemistry/science and psychiatry to give anything more detailed.
Also neurochemistry is massively complicated and hard to monitor, so i think it's going to be a long time before you can get detailed chemical explanations for much of our behavior/feelings/thoughts.
Ok i'll give it a shot.
Your consciousness exists throughout the full bandwith of reality, this includes the 5 senses we experience through our physical body but also infra red, ultra-violet and dark matter, dark energy. Our physical body only exists on a small percentage of this 'reality bandwith'. I don't think it's any coincidence that we only use 10% of brains (at best) and it turns out that our 5 physical senses only percieve a similar amount of bandwith of the full spectrum of reality.
If you shift your oreintation away from the 5 senses to other levels of consciousness or reality bandwith you might discover you have many more senses and forms of perception though in a normal state of consciousness these other forms of perception are usualy overpowered by the 5 physcial senses and therefore become subconscious.
I also think it's likely that the dreamworld and also the spiritworlds and afterlife spoke of by mystics probably has something to do with dark matter. Dark matter incidently is just matter that isn't reflected by light.
I'm not talking about wanting a detailed reductive chemical analysis of the neuro-circuitry behind this.
I think i'm asking science to tell me why it happens when it cant really it can only tell me how...
It could be because once your brain stops being told it has a body it tries to think of an answer, and it may be that the best one it can think off is it's not in the body any more. some people may just feel disconnected some may be able to look around the room (or at least hallucinate it/dream it) depending on what happens in their brain.So why does conscious awareness float away from the body and act as if independant from it. (you see your body lying there and yet you are somewhere else) What reason does the brain have for inducing this???? To all intents and purposes consciousness is dependant upon a functioning brain.
It freaks the hell outta me...and i find normal reality disturbing enough....
The thread is basically nutjobs vs. proven science
