little mod i did today
OCUK Motors in mod looks chavvy shocker!
Looks decent IMO, breaks the front end up a bit.
Danny I can see you've got the UberAwesomeWicked (sorry, I just love them :D ) flat wipers on the back window, but not on the windscreen? :o
i did have them on the front but i really hated the cheap ebay fitment(where they clip on) it was like a big bulge, they also didn't wipe the window properly at speed. the only aero's i'd consider on the front are bosch aero twins but i'd need new arms and it's just not worth it (£80) but yeh i do think aero's are uber cool:D
really? i looked at some in halfords and it said VW fittment only :O
have you got a pic of yours please? and where did you buy them from??
From when I fitted them to my car last year (they're lasting well, conventional ones would be knackered after a year or so :eek: )
And for good measure, my awesome interior LEDs
:D
they look well nice mate, i also have LED lit interior and footwell LEDs aswell :D
EDIT: Ordered some now :D
I'm working on footwell LEDs, just need to find the feed for the others ;)
edit: It wasn't raining in my wiper shot, i just emptied a watering can over it to test them ;)
:D
WHen you say interior LED's, do you mean LED replacement bulbs? If so, where is a good place to order them from as they sound like a good idea :)
Yep I mean LED clusters that replace the standard bulbs in the ceiling lights :)
www.ultraleds.co.uk have a huge range, you'll need to pop out the existing bulbs to find out the type/size.
I got mine from Ebay however, I saw some massive 9-LED ones that looked chunky, ultraleds didn't have any that beefy ;)
they wipe no differently to my normal bosch wipers i took off, they just look cool and work better at speed ie on the motorway there is a lip on them which pushes them down
I find them much better especially at speed, than standard ones. They last longer too. And look nicer ;)
Good work Daniel.
