Pyro Achievements and Unlocks...!
valve messed it up
i hate it when they do that, throw some thing new into the mix then for weeks on end ***** achivement hunters go and spoil the game, if your going to release upgrades do it too all classes muppets... i not going to play it now for a month or so.***** messing up a great game:mad:
It's not really Valve's fault, it's the players that decide to grind on normal playing servers that's the problem. I've been playing on servers with class limits specifically because of this and it's not been a problem.
i myself havent been to bothered about these "achievements and unlockables" as im only playing for fun and dont tend to play medic/pyro as theres usually a handfull already being them on public , while classes like the heavy arent appreciated.
is there still the way to just bung a code in?
Haven't played tf2 since well before the medic stuff came out and don't fancy having to try and do achievements to catch up.
Just had a game now. Terrible with so many pyros. We had half a dozen of them on the final part of dustbowl attacking which we never won as they just had 2 SGs mowing them all down :rolleyes:
So many Pyros using the backburner now. What I can't understand, is that there are 38 achievements but you only need to get a maximum of 22 to unlock all the weapons; compare that to the medic update where you needed all 36 with the other unlocks spread out evenly between.
Saying that, quite easy to spot all the complete noob Pyros around. Makes it even easier when they all have the backburner as they lose their projectile deflection. It's a Demoman's paradise atm.
how many achievements do you need to unlock the Axtinguisher?
edit: oh, 22 ?
10 for backburner, 16 for flare, 22 for axtinguisher (which i must say is overpowered after playing on a class limit server where most people can be ignited)
Is it just me or is the flare gun pretty useless?
Saying it has an arc and moves pretty slow, the burning time and damage caused is pretty awful.
The shotgun is better in most situatinos, but the flare does have its up sides in certain situations, like hitting snipers at distances beyond the shotgun. Plus if you are running towards an enemy, you can quickly flare them from range then continue running and melee them with the axtinguiser, instead of having to wait untill your up close and using the flamethrower to ignite.
