so does this mean it wont work in my Foxconn P35AP-S???
Works fine in my P35 Asus P5K-E
well i have rung ocuk and informed me that the ati 4850 wont work in a pci express 1.0a slot mobo.so thats a bummer![]()
PCIe 2.0 is backward and forward compatible with PCIe v1.x. Graphic cards and motherboards designed for v2.0 will be able to work with v1.1 and v1.0, and vice versa. In some rare cases it is possible that a PCI-E 2.0 card will not work correctly on a PCI-E 1.0a slot. This is only limited to certain video cards.
I have a 8800GTS 512 (PCI Express 2.0) and it wouldn't work in my old ASrock motherboard, which I believe was PCI Express 1.0.
System Requirements
–PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
–450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
–Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSUfor a list of Certified products
–1GB of system memory
–Installation software requires CD-ROM drive
–DVD playback requires DVD drive
–Blu-ray™ / HD DVD playback requires Blu-ray / HD DVD drive
–For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per board (included) are required.
Minimum System Requirements
• Hardware
- Intel
® Pentium® 4 or AMD Athlon
TM
- 1 GB or more of system memory for best performance
- Optical drive for software installation (CD-ROM or DVD-ROM drive)
- A power supply that provides at least 450-watt. The power supply should be with a
known brand and certified to conform to safety regulations. (For the list of certified power
supplies, go to http://ati.amd.com/certifiedpsu.)
• Operating System
- Windows® Vista
- Windows® XP with Service Pack 2 (SP2)
- Windows® XP Professional x64 Edition
• CrossFireXTM
Configuration
If you are planning on using this graphics card as part of a CrossFireX system, the following
is required:
- A CrossFireX certified motherboard with two PCI Express x16 slots and correct chipset driver
- Two GV-R485-512H-B
- A power supply that provides at least 550-watt to ensure the power supply is designed
to accommodate a high-end graphics card with a peak dissipation above 100-watt. The
power supply should be with a known brand and certified to conform to safety regulations.
(For the list of certified power supplies, go to http://ati.amd.com/certifiedpsu.)
* PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
* 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
* Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSUfor a list of Certified products
* 1GB of system memory
* Installation software requires CD-ROM drive
* DVD playback requires DVD drive
* Blu-ray™ / HD DVD playback requires Blu-ray / HD DVD drive
* For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per board (included) are required
Well, my 8800GT and 8800GTS G92 which is pci-e 2 worked fine in it although at the time of 8800GT launch there was some debate then as well.
Pci-e 2 is meant to be a standard so I can't see why a 4850 wouldn't unless ATI broke the standard?![]()
have u tryed everest ultimate to find out?well i have a decent psu seasonic s12-500w and i know the pci express is x16 for shaw . hmmm gamble or play safebeen trying to sort this carp out for two days now getting irritating.
