There's only GDDR5 4870's listed there. With Euro -> Sterling. £170.![]()
You're a bit slow... check the review thread.If the 4870 reviews are reasonable on release (no reason they shouldnt be)
You're a bit slow... check the review thread.![]()
If the 4870 reviews are reasonable on release (no reason they shouldnt be) I am hoping to build a rig with CrossfireX of two 4870's and a single 3800/4800 for a 2nd screen (as I believe you still cant dual screen with CrossfireX/SLI enabled?)
i got my 4850 clocked to over 700mhzturns out the ccc was forcing it to 700mhz so I just disabled overdrive, now currently at 740mhz 1.23v
well it will do 750mhz no problem and once I get it under water I'm hoping for another 100 or so mhz for daily usage.
So regarding the 4870 it really comes down to how much of a difference the gDDR5 will really make, and if you want to bother fiddling around with the 4850 or not.
In the anandtech review they bench crysis at 1680x1050 no AA, but it seems their results are high for the "very high" settings, so I think they are just running it on high.
I will try it now and see what i get.
...ok well I just ran the crysis bench that anandtech ran and I've already outperformed their 4870 which got 35.6fps...however I would imagine the gDDR5 would come into play more when AA is applied.
and I figured the pencil mod out because it was almost exactly the same as the 38xx series. Just check the modding and bios section on XS for more info.
