- 27 Jan 2003
- Chesterfield, UK
Seriously impressive! Incredible bandwidth @ 4800. Would be amazing if you could reach 5000! (only 50Mhz 'real' more, and would make it 1400ddr above standard!
Also, people often forget about airflow around gfx cards when they get watercooling, so it just goes to show how good it can be when you set it up properly with airflow running alongside
Also, if it does 880 on stock volts, it sounds like you have a VERY good chip to add a titchy bit moreShame we can't do the old bios volts (or can we?) or use ati tool anymore for increasing voltage on ati cards
Matthew
If I get time later I will try and push the memory. With regard to voltages I'll probably have a crack if it can be done via a Bios mod or Overclocking tool. Not too fussed about pencil/hard mods. At the end of the days its pretty fast at stock.
Very, very impressive card. Its well built and runs very quiet with the stock fan although 80'c idle seems a tad high. I'm getting the feeling this is going to be another 9800 Pro. ATI have done us all proud this time around and all credit to them. One of the best uprgades I have done in a long time.
