In some parts with the cfg I use I play at 4xAA at 1680x1050, gets rid of most jaggys, and you say its not real AA?
Not impressed with the screenies linked above though, I might try CCC again once I have backed my crysis installation up but its not very good in long distance, blury just how I had it.
g_dof_ironsight [0,1] - If set to 0, disables the Depth of Field (DOF) effect which occurs when using your weapon's iron sights. This makes everything much sharper, and can improve FPS, but reduces realism for some people (system).
g_dofset_maxscale [value] - This setting, along with g_dofset_minscale, can be used to adjust the extent to which the Depth of Field effect blurs surrounding objects which are not in focus. For example setting both values =1 results in more subtle blurring around the edges, while setting both to =3 makes the blurring more prominent (system).
I don't get how people play with these configs, they look worse than the default settings. They turn off detail from a medium-long range to give you some more detail close up... essentially making them nice as screenshot configs but nothing else. Playing with them is impossible when all you notice is what they turned down / off in the process.
the game looks pretty out of the box
it takes 4 hours to complete
multiplayer sucks
no replay value
why do people bother modding it?
Farcry was a much better game imo
Where did I say it's not real AA? Jumpy or what? I was referring to the notion of Crysis' relatively poor non-multisampling edge AA
In these configs, they're all using r_edgeaa=1 which isn't even proper multisampling, just blurs the edges. The biggest difference one can do is to enable 4xAA at least.
When I say I can 'only use 4xAA at 1280x1024' which I assume you read as 'only 4xAA' implying it's too small or inadequete, I meant that the resolution itself is tiny. I could do 4xAA at 1680x1050 but it dips too much.
both
I just tried CCC again but DX10, my saves wont low, will try DX9 one soon.
With CCC, I believe you have to start a new game
Uh, that sucks, no CCC for me I'll go try a better cfg![]()
I need some help.
Can someone try recreate this? I dont know how I got mine like it, but the cfg I thought I used dont look like that.
