Have you done some bios tinkering as them default clocks looks different to what's stated on the link...
The card has three clocks, idle, low 3d and full. Those are the idle clocks, run a game and fire back to GPUz and it will (should) show the increase to the 3d clocks.![]()
Just got a 280, wonder if someone can shed light on the core and memory clock values under the sensor part. Is that a bug within GPUz?
Yep. I kept hitting a wall with mine linked, unlinked them and pushed the shaders as far as i could then stepped it back a bit and then started to tinker with the other two settingsI think I see what I'm doing wrong.
Looks like it's the shaders that give out first.
