Catalyst 8.8 released
i've installed it before, a while ago now infact and it gave me nothing but problems.
you have to set your location to the US and then install it but after you change it back to UK updates screw up cos vista tries to get updates that it needs but wont install them as your set to UK again.
unless all thats changed recently?
I'd try my best and get this on for help as it ironed all my m8's problems out.
ah i see well Its been working perfectly after using the standalone install. Used it on both my Vista machines.
Was covered further back in the thread (when i asked about it :p), been removed to make it simpler (as those settings didn't do anything anyway apparently as the drivers controlled when they were used), so all you get now is the slider with Performance at the left, Quality at the right.
sweet all working fine then? Im surprised you bought another for testing purposes, you can always return it under DSA ;)...if you want :D
well i had a waterblock on the first card so the stock cooler got "looked at" meaning i couldn't return it, returning it under DSA was my plan but i won £35 on the scratchcards today so its a keeper i think lol
