There's lots of different ways to get make a magic memory stick, which probably doesn't help the confusion.
You can get installers that you simply point it to the files you need, tell it where your memory stick is, and then let it create the files on the stick.
I've know of an installer that's very first time user friendly. If you want to email me (check trust) I'll happily point you in the right direction.![]()
The rain forest definitely sell the TOOL/Pandoras batteries, it's where I got mine.
Upgrading from one CFW to the next is dead easy, you grab the latest CFW and OFW from Dark Alexs site, copy them both to the PSP and run the installer that shows up.![]()
OK, thanks, I may well take you up on that.
Vin.
