Carbon Monoxide Alarm Just Went Off!!
Status
Not open for further replies.
Permabanned
17 Jul 2008
a House
our carbon monoxide alarm has just gone of, my dad reset power and checked everything, all seemed ok, so we headed back bed, just gone of again so he cut power to it and parents and bro have gone bed, is there anything to worry about, should i call the fire brigade?
See if you can call them in the morning... when you are all dead.
What do you think you should do...
When a carbon monoxide alarm goes off, it usually means carbon monoxide is present, I'd have thought. I'll look out for your story on the BBC tomorrow.
First of all why would you call the fire brigade - you dont have a fire. You need someone to check your gas appliances as they are not burning correctly if your getting CO. If the alarm is battery operated take it out side and it should stop as there should be no CO outside, if it doesnt then it may be a faulty battery. If it is a mains operated detector and it has gone off again after being reset i would suggest getting someone out right now to look at your appliances. You cannot take any chances with CO.
Wait, your carbon monoxide alarm went off twice and you ignored it, and then come to the internet to ask on whether you'll be safe?
Jesus. Got any last words?
Crewe, if you can send some-one round, i cant phone them, i dont know what to say!
How about,
"Our Carbon Monoxide detector went off twice, can you send some one out to check everything please. I don't want to die."
Then they will prolly ask for your address so you tell them that.
That website (if you looked at it) has a 24 hour emergency line. I'd consider calling it if I were you.
Status
