Man of Honour
 - 12 Jul 2005
 - Aberlour, NE Scotland
Update 20/03/09
Now includes E2140 results from 1.6-3.6Ghz and E8500 E0 results from 2.4-4.5Ghz. All done with the exact same components and drivers to give true comparisons.
Hi guys, i know some of you have been waiting for this so here it is at last. Bear with me as this is my first review.
I set about doing this to try to offer some help to those who have been wondering if it is worth upgrading from what they have. I have done a full suite of benchies with a E2140, E4300, E5200, E6600 and E8500. I also have partial results from a Q6600. Benching was performed in my main rig to keep it all consistent. The specs are as follows:-
Asus P5E X38 with bios 903.
2x1Gb Crucial Ballistix PC2 8500.
Zotac 8800GT @701/1836/1950
Creative X-Fi Extreme Gamer
Zalman ZM750-HP Psu.
Seagate 7200.10 320Gb sata2 hdd
Samsung 20x DL DVDRW
TT Aluminium Armour.
High end watercooling setup.
178.13 WHQL driver.
8.09.04 Physx driver.
Windows XP Home SP3.
E2140 - 1.6Ghz - 8x200 - 1mb L2 - 65nm Conroe core - SLA93 - FPO/Batch # L732A988 - Vid 1.2125.
E4300 - 1.8Ghz - 9x200 - 2mb L2 - 65nm Allendale core - SL9TB - FPO/Batch # Q641A275 - Vid 1.3250.
E5200 - 2.5Ghz - 12.5x200 - 2mb L2 - 45nm Wolfdale core - SLAY7 - FPO/Batch # 3827A333 - Vid 1.1625.
E6600 - 2.4Ghz - 9x266 - 4mb L2 - 65nm Conroe core - SL9ZL - FPO/Batch # L702C486 - Vid 1.3500.
E8500 - 3.16Ghz - 9.5x333 - 6mb L2 - 45nm Wolfdale core - SLB9K - FPO/Batch # Q820A837 - Vid 1.212.
Q6600 - 2.4Ghz - 9x266 - 8mb L2 - 65nm Kentsfield core - SLACR - FPO/Batch # Can't remember - Vid 1.3500.
I tested at the following speeds:-
E2140 - Stock (1.6Ghz) - 8x200, 1.22v, ram @800mhz.
- 2.4Ghz - 8x300, 1.25v, ram @960mhz.
- 3Ghz - 8x375, 1.35v, ram @999mhz.
- 3.6Ghz - 8x450, 1.472v, ram@1081mhz.
E4300 - Stock (1.8Ghz) - 9x200, 1.3v, ram @800mhz.
- 2.4Ghz - 9x266, 1.3v, ram @1066mhz.
- 3Ghz - 9x333, 1.4v, ram @1066mhz.
- 3.4Ghz - 9x378, 1.475v, ram @1008mhz
E5200 - Stock (2.5Ghz) - 12.5x200, 1.16v, ram @800mhz.
- 3Ghz - 12.5x240, 1.16v, ram @960mhz.
- 3.6Ghz - 12.5x280, 1.325v, ram @960mhz.
E6600 - Stock (2.4Ghz) - 9x266, 1.31v, ram @1066mhz.
- 3Ghz - 9x333, 1.35v, ram @1066mhz.
- 3.6Ghz - 9x400, 1.45v, ram @1066.
E8500 - 2.4Ghz - 9x266, 1.2v, ram @1066mhz.
- 3Ghz - 9x333, 1.2v, ram @1066mhz.
- 3.6Ghz - 9x400, 1.2v, ram @1066mhz.
- 4Ghz - 1.285v, 9.5x421, ram @1058mhz.
- 4.5Ghz - 1.4v, 9x500, ram @1000mhz.
Q6600 - Stock (2.4Ghz) - 9x266, 1.31v, ram @1066mhz.
- 3.6Ghz - 9x400, 1.456v, ram @1066.
The E5200 has a disadvatage when it comes to benching as it has a high multiplier but a low fsb. This means it has less bandwidth available and i could'nt run the ram as fast as i could with the other cpu's. Drop the multiplier and increase the fsb and it more than makes up the difference. More about this later. The benchies i used are:
3Dmark 01, 03, 05 and 06. Default settings.
Aquamark 3. Default settings.
Super Pi 1m, 16m and 32m.
Nuclear MC. Default settings.
Cinebench R10. Default settings.
Fluidmark v1.00. 1280x1024, Default settings.
Lightsmark 2007. 1280x1024 Default settings.
Company of Heroes Opposing fronts in built test. 1280x1024, all set to high or
Ultra where available and 8x AA.
World in Conflict. Built in test. 1280x1024, high no AA.
Crysis. Crysis benchmark tool, all high no AA, 1280x1024.
Far Cry. Hardware OC Benchmark. 1280x1024, default settings.
Prey. Hardware OC Benchmark. 1280x1024, default settings.
All tests run 3 times and average scores taken. One of the reasons it took so long. Anyway, here's the first lot of synthetic benchies:-
As you can see, it's a bit of a mixed bunch. Sometimes the E5200 is beaten by the E4300 and sometimes it's the other way around. What is impressive is that it beats the E6600 in 06. It get's a hiding in Aquamark 3 though. This is mostly due to the low fsb. As a experiment i dropped the multiplier down to 9x and increased the fsb to 266 to get the same 2.4Ghz as the E4300 and E6600 and it beat the pair of them in everything but Aquamark. The E6600, Q6600 and E8500 were all still out in front. Probably the extra L2 Cache was having an effect here. The E2140 is hopelessly overwhelmed and the lack of cache (only 1mb remember) is hurting it.
On to the next batch.
I was extremely impressed by the E5200 here. In NuclearMC, it beats even the E6600 in everything but the Alu test and it is'nt far behind in that. Most impressive. Do the same with dropping the multiplier and increasing the fsb and it does beat the E6600. The poor E2140 and E4300 get left behind quite considerably although they do respond very well to clocking. The E5200 is'nt far behind the E6600 in Super Pi either. The E8500 is all powerful which is to be expected.
178.13 WHQL driver.
 Thanks for taking the time to do all that.
 (well, you did already answer that)
