CD eject problems
After ejecting a CD tray containing a disc, the tray will be immediately retracted, making it difficult to remove the disc (bug 283316). This can be worked around by pressing the eject button again before the disc is fully mounted, after which it will stay open. We expect to fix this in a post-release update.
Just saw this in the 8.10 release notes:
Priceless.![]()
no problems here, im using a laptop!
flawless for me, no errors or bugs encountered as of yet, fingers crossed.
Aren't you the lucky one!
I might set this one up running now on my fileserver. I want to see KDE4! I guess I better install more RAM though, 256MB might not cut it =/.
Yes but because 8.04 was an LTS release, the updates are set to only check for "LTS updates", if you change the update settings to "normal updates", the upgrade will show up on the updater.
More info here: http://www.ubuntu.com/getubuntu/upgrading
Update to 8.10 kubuntu went well, very easy in fact. It's just a bit slow now. Mind you it's quite old now - a Del Inspiron 8500. Shame. May have to switch to the gnome version. Probably uses less resources. Sure looks pretty tho.
I always used the alternate install because i presumed that was the way to do a fresh install and the pc was an old one anyway, now i have a better one i was thinking of just getting the desktop version but can it do a fresh install from boot?
My gnome doesnt load anymore !
Stops at 'Running local boot scripts (/etc/rc.local)'
Any ideas?, was a base install of 8.04 with default updates only
I can get to a prompt by pressing cnt+alt+f1, but im stuck from there![]()
dmesg | more
